1992 Chevy Corsica water in front floor boards
122,250 MILES • 6 CYL • 2WD • AUTOMATIC
SARAA
My heater core was replaced and now I have water leaking in my front floor boards, more so on the driver side. I am not haveing to put water in the radiator. I believe my a/c drain is draining inside the car. Where is the a/c drain located exactly under the car and could it be a hose inside to the drain that got disconnected when the heater core was replaced?
Sep 27, 2008 at 10:04 AM
  • 110,248 POSTS
Hi:
If the only time you get water is while using the AC, then I think you're right. The drain hose may be hard to find under the dash, but you will find it under the car behind the engine. It will be a black rubber hos coming from the firewall. Most likely, it will be on the passanger's side.
Let me know if you have any other questions.
Oct 2, 2008 at 6:44 AM
