1992 Chevy Corsica Oil Pan Removal
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
GIGGIDY
I've heard many different theories on how to remove my oil pan. All of them sound like alot more parts being removed than necassary. Looking for some clarification on what parts really need to come off.
Aug 10, 2009 at 6:33 AM
  • 110,248 POSTS
I believe all you need to do is disconnect the motor mounts and lift the engine for it to come out. It's been some time since I did one. Is there a lot in your way? Also, you will need to remove the starter to access the bolts behind it.
Aug 10, 2009 at 3:59 PM
