1992 Chevy Corsica How do I fix the problem?
112,800 MILES • 6 CYL • FWD • AUTOMATIC
CAMERONBELL
My car Cranks,but doesn't start. There's no crank signal on the computer. There's no spark. It has fuel pressure. I have no codes for diagnostics check on my computer. Please Help.
Feb 13, 2010 at 2:33 AM
HMAC300
  • 48,601 POSTS
you need to check the ohm resistance on teh crank sensor. not easy to get to as it'son the back of the engine and above the trans. If the ohms are good then it may be the circuit board or coil. I'd bet crank sensor though.
Feb 17, 2010 at 12:34 PM
