1992 Chevy Corsica HEAD LIGHTS
93,000 MILES • 6 CYL • FWD • AUTOMATIC
GAMESTUD
I HAVE NO HEADLIGHTS,REPLACED HEADLIGHT SWITCH.STILL NOT WORKING,I NOW HAVE A PROBLEM WITH HIGH BEAM SWITCH.I TRY TO
PUT HIGH BEAMS ON ( THEY ONLY STAY ON WHEN
I HOLD SWITCH UP).WHEN I LET SWITCH GO THEY GO OFF.I TRY TO DRIVE WITH HIGH BEAMS AT NIGHT UNTIL I RESOLVE HEADLIGHT SWITCH PROBLEM.ARE THE HIGHBEAM SWITCH & HEADLIGHT SWITCH INTERCONNECTED IN SOME WAY?
Feb 15, 2008 at 9:47 AM
MASTERTECHTIM
  • 4,750 POSTS
low beams run through the high beam switch. this is most likely causing all your problems.
Feb 15, 2008 at 10:31 AM
