1992 Chevy Corsica Engine Stop working
1992 CHEVROLET CORSICA
144,325 MILES • 6 CYL • FWD • AUTOMATIC
SKULLYJ
  • 5 POSTS
What to repair on my engine when it's hard to start and when it run, it idle fast and shut off like the key has been turned off.Also when it's running when I press the gas pedal it kind of choke.I;ve replaced the TPS.IAC.O2 sensor.When it run it run real good.I would really appreciate your HELP. Thanks In Advance
Oct 24, 2009 at 11:11 AM
  • 110,244 POSTS
Have you checked fuel pump pressure? When was the last tune up? Have you checked for vacuum leaks? EGR?
Oct 29, 2009 at 1:08 AM
SKULLYJ
  • 5 POSTS
[quote:724e9c7d09="Jacobandnickolas"]Have you checked fuel pump pressure? When was the last tune up? Have you checked for vacuum leaks? EGR?[/quote:724e9c7d09] Yes I have had the fuel pressure checked and the mechanic said it was good.No vacum leaks.
Oct 30, 2009 at 6:06 AM
  • 110,244 POSTS
More than pressure I am worried about fuel pressure drop off. Did he check that?
Oct 30, 2009 at 6:28 AM
