1992 Chevy Corsica EGNITION KEY REPLACE
124 MILES • 6 CYL • FWD • AUTOMATIC
STEVENGILL
HOW DO YOU GET THE OLD LOCK OUT? HAVE PARTS CAR WITH GOOD KEYS OLD CAR KEYS WON'T UNLOCK THE STERRING
Dec 17, 2009 at 12:27 PM
IMPALASS
  • 3,112 POSTS
Hello
Sorry the information we have doesn't have any pics to go with the directions.
I also included a couple of other things just in case you needed it.
LOCK CYLINDER
Removal & Installation
Remove turn signal switch. With ignition key removed, remove buzzer switch. Insert key into lock cylinder. Turn lock cylinder to LOCK position. Remove lock cylinder retaining screw. Remove lock cylinder. To install, reverse removal procedure.
LOCK HOUSING
NOTE: Lock housing, which houses the lock cylinder, is the main housing around the column.
1. Remove steering wheel, SIR coil assembly (if equipped), turn signal switch and lock cylinder. Remove dimmer and ignition switches. Remove cover from lock housing. Disconnect cruise control switch connector (if equipped) near multifunction switch.
2. Disconnect multifunction switch connector. Set multifunction switch lever in OFF position (centered), grasp lever and pull straight out to remove. Remove lock housing screws. Remove lock housing. To install, reverse removal procedure.
Dec 17, 2009 at 12:35 PM
IMPALASS
  • 3,112 POSTS
Hello
One other thing. It looks like you may have a recall on your vehicle. The dealer may fix this for free. Please contact the dealer service department, give them the VIN number of your car and have them check on this to see if it applies to you. This is an old recall and it may not apply but it doesn't hurt to ask.
I have included it below.
SERVICE BRAKE LAMP SWITCH BECOMES INOPERATIVE
NHTSA RECALL BULLETIN
Reference Number(s): 92V185000
Related Ref Number(s): 92V185000
ARTICLE BEGINNING
VEHICLE DESCRIPTION
Model(s): 1992 Chevrolet Beretta
1992 Chevrolet Corsica
Campaign No: 92V185000
Number of Affected Vehicles: 140661
Beginning Date of Manufacture: 1991 MAR
Ending Date of Manufacture: 1992 JUN
Passenger cars.
SYSTEM
Lighting; stoplamps.
FAULT
Burned, Overheated, Burnt out, Melted
DESCRIPTION OF DEFECT
The service brake stop lamp switch becomes inoperative.
CONSEQUENCE OF DEFECT
The inoperative stop lamp switch will not illuminate the stop lamps when the brake pedal is depressed. This would not adequately inform other drivers of the vehicle operator's intent to stop or slow down.
CORRECTIVE ACTION
Replace the stop lamp switch and correct the wiring in the connector of the stop lamp switch wiring harness.
NOTE
If the failure occurs during three consecutive service brake applications the amber anti-lock brake system (ABS) telltale lamp may illuminate indicating a problem with the system.
Dec 17, 2009 at 12:37 PM
