1992 Chevy Corsica 1991 Chevy Corsica has no spark.......
1992 CHEVROLET CORSICA
240,000 MILES • 6 CYL • FWD • AUTOMATIC
IRELAND8166
I have a 1991 Corsica, while driving down the road the car just stopped running. I had it towed home and have since replaced the MAP Sensor, the Crank Sensor and the Timing Chain (as it was snapped) Gears and Damper. There is no spark at all and even the mechanic is stumped. If anyone knows anything else I should try please let me know asap. Thanks so much...
Nov 9, 2009 at 8:36 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 9, 2009 at 8:46 AM
IRELAND8166
We have replaced the ignition control module and crank sensor and still have no spark. Could it be the ignition switch itself causing the problem?
Nov 10, 2009 at 12:39 AM
