1991 Chevy Corsica Tie Rod PLEASE HELP
1991 CHEVROLET CORSICA
186,000 MILES • 6 CYL • FWD • AUTOMATIC
MANNMACHINE
  • 6 POSTS
My Corsica's front driver side wheel woobles so bad people pull up next to me to warn me... I took it to have them balanced and rotated but he told me that the rubber bushing on the tie rod was gone.
Can I replace the rubber with out replacing the whole thing? If so, Would it be cheaper to do it this way?
Jun 20, 2010 at 4:21 PM
  • 31,937 POSTS
The tie rod end will have to be replaced as a unit, the rubber is just a dust boot.
mark (mhpautos)
Jun 20, 2010 at 4:29 PM
MANNMACHINE
  • 6 POSTS
Thank you for your help. The rod itself is fine. Can I just replace the dust boot or is that part of the unit?
Jun 20, 2010 at 4:47 PM
  • 31,937 POSTS
You can just do the boot if you like, but a tie rod end is quite cheap to replace as well.
mark,
P.S. what was the cause of the wheel wobble?
Jun 20, 2010 at 5:12 PM
MANNMACHINE
  • 6 POSTS
The wheel wobbles because of the boot being gone... The entire rod ( which I can access from under the hood) moves. I can grab it and wiggle it. Im not sure exactly how bad the tire wobbles cos I cant see it when I'm driving. However the steering wheel, dash and everything shakes pretty bad. I'm afraid of the whole wheel flying off.
Jun 20, 2010 at 7:06 PM
  • 31,937 POSTS
This will not just be the rubber boot, as i said that is just a dust boot, sever steering vibration may be due to the actual tie rod end being worn, you run the risk of total steering failure if this is not rectified, i strongly recommend having the steering & suspension checked over by a qualified mechanic, who ever told you that the cause of the problem with the steering was the rubber boot is a fool.
Mark (mhpautos)
Jun 20, 2010 at 8:00 PM
MANNMACHINE
  • 6 POSTS
Well it IS highly likely that the rod is worn. The rod is sturdy at the wheels end. It is loose at the center link, which is the thing I can grab and wiggle. It doesnt seem very worn though, the rubber is just missing which causes the wheel tho wobble and the car to shake. When I get it up over 60mph or below 20mph it rides smoothly. Thats why I wanted to just replace the bushing... aside from the fact that while a tie rod is pretty cheap, I will also need an alignment. I cannot afford all of that at this time. Labor charges are insane and since I'm a girl mechanics usually try to swindle me. There are also other issues Im having with the radiator hose and the air filter.
Jun 20, 2010 at 8:27 PM
