Engine Performance problem
1991 Chevy Corsica 4 cyl Two Wheel Drive Automatic
Car idles rough and somtimes stalls when I stop. I,ve changed: plugs, plug wires, idle air control valve, fuel injector, fuel filter, PCV valve, intake manifold gasket, TBI to intake manifold gasket and crank position sensor. I,ve checked: timing chain, throttle position sensor, vacuum hoses (found no vacuum leaks) (vacuum is unsteady do to poor idle), fuel pressure (11.5 psi), and cylinder compression (around 125 psi). All good. No error codes.
Jun 30, 2008 at 9:13 PM
