1991 Chevy Corsica car stalling
JIMDOG1982
  • 1991 CHEVROLET CORSICA
Engine Performance problem
1991 Chevy Corsica 4 cyl Front Wheel Drive Automatic 114.00 miles
hi my name is jimmie I have 1991 chevy corsica 2.2 4 cylinder when car gets to a quater on the heat gagae then car starts to stall out ive replaced the fuel filter the spark plugs and plug wires ive had bought coil packs but to much of a pain in the butt to get to so I said for get it when it gets down to 15 miles per hour or more it clonks out then starts back up again and runs fine I can here fuel pump runing and wqhen it gets under 30 miles and hour the car shakes and pulls a vibration really rough and its driving me bonkers anyway suggestion on why this is doing that
Thursday, January 22nd, 2009 AT 7:46 AM
  • 109,885 POSTS
Hi:
Check to make sure the catylatic converter isn't plugged. Also, does it always start right back up when it dies? Have you ever checked fuel pump pressure?
Tuesday, January 27th, 2009 AT 6:30 PM
JIMDOG1982
I checked my fuel pump its ruining fine its starts back up and when u get down to 30 miles and hour it starts running rough and vibrates horrible when it starts and it passed this years emission so I so I dont thing the cat would be plugged up I replaced the starter I did a full maintain maintenance on it new flush transmmission fluid change the heater doesent wrok and the air need to be charged but thats all it wrong with it the check engine light doesent come on so I have spark in all my spark plugs I just changed the wiires and plugs it self im tryingto find a cheap easy way to fix it please respond thanks
Tuesday, January 27th, 2009 AT 8:35 PM
  • 109,885 POSTS
Hi:
try taking it to a nationally recognized parts store and have them scan the computer for codes. They will do it for free and it may provide insight.
Let me know what you find.
Tuesday, January 27th, 2009 AT 9:46 PM
JIMDOG1982
I hhave to it to checkers and the dam machine dont work on my plug it dident pop up an thing
i was woundering ebcause auto doesent do anything newer then 96 and im in arizona where I can take it to get it done free they tell the check engine light haves to be on first for it to work?
Tuesday, January 27th, 2009 AT 11:40 PM
