1991 chevy corsica 3.1
KEITH8959
i have a 91 corsica with a 3.1 multi port fuel injection the problem is no fuel pump noise when key is turned on. i have tested both fuse and relay and replaced oil pressure switch which grounds circuit. dose the initichal charge come from the ecm and how to test it before i replace it i supplied 12volts to pump at tank plug and it runs. but it dose not run when i supply 12 volts to test lead at wiper motor. i hope its not the computer help please!
i have tested the fuse and relay i believe that the engine controle module is not sending the key on signalto the relay which completes the curcit and charges the relay.
Jun 7, 2007 at 1:29 PM
E40WATER12
  • 522 POSTS
When u turn the igintion to ON position, And you dont hear the fuel pump kick on, 2 things to have to check, 1. if youre fuel pump relay works, Check the fuse. If that checks out ok. 2. U need to get pressure test done on youre fuel pump, No psi, while cranking the engine youre pump is toast, Then u need a new one.
Jun 9, 2007 at 11:02 AM
