1990 Chevy Corsica Idle above 1100 RPM
RAELSTON
  • 1990 CHEVROLET CORSICA
  • 4 CYL
  • 4WD
  • 88,000 MILES
I just bought this car and an emissions test is required to transfer the title over. I was unable to do the test however because the car's idle is too high. Whatever that means. I was told to take it in somewhere to get the "idle set below 1100". What does this mean exactly? Isn't the onboard computer supposed to regulate this? I have limited funds at the moment and want to get as much information as possible before I take it in to a mechanic so that I won't be taken advantage of.
Thank you!
Thursday, September 2nd, 2010 AT 7:38 PM
LEGITIMATE007
  • 5,121 POSTS
The idle air control valve takes care of this, but if it is faulty or dirty, you will get all kinds of different idling, start by cleaning the throttle body and Iac. Making sure there are no vacuum leaks
Thursday, September 2nd, 2010 AT 7:55 PM
LEGITIMATE007
  • 5,121 POSTS
Is there a check engine light on?
RAELSTON
Thank you for answering so quickly! No, the check engine light is not on.
Thursday, September 2nd, 2010 AT 8:11 PM
LEGITIMATE007
  • 5,121 POSTS
Ok then go ahead and have the idle air control valve and throttle body cleaned
Monday, September 6th, 2010 AT 12:20 PM
