1990 Chevy Corsica fuel line
PHIL56
1990 Chevy Corsica 6 cyl Front Wheel Drive Automatic
how do you replace a fuel line on a 1990 corsica
Jan 13, 2009 at 11:00 AM
  • 110,248 POSTS
HI:
Does the entire fuel line need replaced? If so, buy a coil of the correct size of steel line, a good pipe bender, and the necessary fittings. You will also need a tool to flange the ends (I believe). The rest is a matter of making a new line that is shapped like the old one and replace it. You may need to remove the fuel tank to get to the hose.
Let me know if you have questions.
Jan 27, 2009 at 10:50 AM
