1990 Chevy Corsica crank position sensor
CHERIANN62
  • 1990 CHEVROLET CORSICA
  • 6 CYL
  • FWD
  • 11,000 MILES
How many ohms is OK?
Where do you check for the ohms?
Where is the sensor?
Should the ignition be on or off when checking?
Saturday, April 10th, 2010 AT 3:03 PM
HMAC300
  • 48,601 POSTS
You will have to find the specs for the ohm reading. It's on the back side of the motor by trans on firewall side. You have to check between posts of the sensor for ohms and don't turn the switch on unless you want to screw up your vom.
Tuesday, April 20th, 2010 AT 6:19 PM
