1990 Chevy Corsica
106,000 MILES • 6 CYL • FWD • AUTOMATIC
JESSEBWRIGHT
the car sat for 3 years , it will not shift past third gear,and the speedometer will not work. The one time it shifted through overdrive, the speedometer worked correctly. Could the modulater valve be the problem?
Aug 19, 2009 at 10:04 AM
HMAC300
  • 48,601 POSTS
i would check and see if the spped sensor is working as it runs the spedometer as well. If the computer doesn't read any speed it won't let it shift. It could be a modulater as well or a broken/pinched vacuum line leading to it.
Sep 29, 2009 at 11:59 AM
