1989 Chevy Corsica Oil Pressure Sensor Location
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOINTHEIR
Do you have a diagram or tell me where the location of the oil pressure sensor is on a 1989 Chevy Corisca.
I have a very low oil pressure gauge reading which does not move up unless you rev the engine. What is the problem.
Apr 29, 2009 at 7:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
For the 2.0L engine the oil pressure sender/switch is under the intake manifold, at the right rear of engine. For the 2.8L engines it is near the oil filter, at the right front of the engine. Place a "T" at the sender and use a manual oil pressure gauge to test pressure. If it shows same as the instrument panel gauge then suspect faulty oil pump. If it shows good then suspect faulty oil pressure sender/switch.
Thanks for using 2CarPros.com!
Apr 29, 2009 at 9:11 AM
