1989 Chevy Corsica hey
12,635 MILES • 4 CYL • FWD • AUTOMATIC
KEN85
my car it will run fine for awhile but then its stals out on me ill come to a stop an in will stal then when i put it in drive it will shut off do you know what this means
Sep 24, 2010 at 5:02 AM
WRENCHTECH
  • 20,760 POSTS
I'm assuming it starts right back up.
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Sep 24, 2010 at 5:52 AM
