1989 Chevy Corsica hesitation
1989 CHEVROLET CORSICA
143,000 MILES • 6 CYL • FWD • AUTOMATIC
RCMSFATBOTTOMGIRL
when I first crank my car it runs rough like not getting enough gas I pump the gas but it only acts like it gets the gas when I let off the gas pedal and before I can drive the car I have to wait til it starts running smooth before I can go then when the car stops and I go to take off it hesitates then takes off what could be causing this we have replaced the fuel regulator fuel filter coil pack that was going bad there is also a noise that sounds like air leaking while driving down the road please help I really need to get this fixed.I have 2 young boys that are both sick and we absloutely need this car
Oct 13, 2008 at 7:36 AM
Possible Causes of Engine Hesitation/Poor acceleration
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Oct 15, 2008 at 11:21 PM
