1989 Chevy Corsica Brake light
OCHOA
Electrical problem
1989 Chevy Corsica 4 cyl Two Wheel Drive Automatic
Hi when i use my left turn signal, the left brake light goes out (unless) i go all the way up (right signal) then back to the neutral posistion, could you please tell me what this might be and if i would be able to fix it myself? i know a good amount about fixing just not diagnostics
Nov 27, 2008 at 4:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check multi-function switch (turn signal switch) and related wiring/wiring harnesses for shorts in circuit or loose/faulty wiring.
Nov 27, 2008 at 6:15 PM
