1989 Chevy Corsica 89 Corsica headlights work sometimes
188,000 MILES • 4 CYL • FWD • AUTOMATIC
DGRANT3211
Sometimes the headlights will work sometimes they won't. They always stay on bright. If i pull and push on the blinker lever sometimes they will come on. Left blinker only works if pulled back toward driver, right side works correctly. Is the problem on the lever or on a switch somewhere on the column? Do i need steering wheel pulled to fix it?
Dec 24, 2008 at 9:33 AM
CARMAT
  • 6 POSTS
what you need to do is buy a head light switch it is located on your steering column not hard to replace and its not expensive i had the same problem with my head lights hope this helps tell the people at the auto parts store its the one on the steering column
Jan 28, 2009 at 4:02 PM
