1988 Chevy Corsica noises around the engine
1988 CHEVROLET CORSICA
170,000 MILES • 6 CYL • FWD • AUTOMATIC
ERIC ENGINE
  • 5 POSTS
my engine hasnt made a noise till last night when i started it, then it started a ticking noise, and when i hit the pedal the ticking starting going faster. This is the first time it has happened, i wanted to know what is wrong?
Nov 27, 2008 at 10:31 AM
  • 31,937 POSTS
Hi there,
A ticking noise can often be a noisy lifter or lash adjuster, if so often a oil change with a good quality flush can fix the problem, also a small leak at the exhaust manifold can also tic, check this out.
mark (mhpautos)
Nov 27, 2008 at 10:38 AM
