1988 Chevy Corsica keep stalling out
132,000 MILES • 6 CYL • FWD • AUTOMATIC
ICKOLIVER2009
im having problems when its cold it seems to drive fine but later after driving it it will stall out just quite running i stat it back up run fine but as soon as i put it in drive and press the gas it stalls out but if i just put it in drive sometimes abs let it pull itself and barly press the gas until i get to about 15 m,ph it will take off again with no problems
Oct 17, 2009 at 11:37 AM
  • 75,988 POSTS
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Oct 17, 2009 at 11:38 AM
