2008 Chevy Colorado ckunk
27,000 MILES • 4 CYL • 2WD • AUTOMATIC
GRAPEAPE111
This started better part of a yr ago & has just gotten worse. When I make a left turn, if the pavement is uneven, unless I take it very slowly (and if the surface is rough enough even that might not prevent it) I get a "clunk ", seems to be pass. rear. It has just gotten louder, rougher, & more often.
Dec 22, 2009 at 4:09 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check the right shock for oil leak and mount. Also check U bolts that hold spring to axle maybe loose.
Thanks for donate
Dec 22, 2009 at 7:16 AM
