2007 Chevy Colorado emission code p0449
2007 CHEVROLET COLORADO
STEVEO6777
Computer problem
2007 Chevy Colorado Two Wheel Drive Automatic 43.158 miles
need to find out where the evaporative emission canister is on the truck
Oct 15, 2010 at 12:12 PM
BMRFIXIT
  • 19,053 POSTS
A battery voltage is supplied to the evaporative emission (EVAP) canister vent solenoid valve. The control module grounds the EVAP canister vent solenoid valve control circuit to close the valve by means of an internal switch called a driver. The scan tool displays the commanded state of the EVAP canister vent solenoid valve as ON or OFF. The control module monitors the status of the driver. If the control module detects an incorrect voltage for the commanded state of the driver, this DTC sets.
Evaporative Emission (EVAP) Canister Vent Solenoid located On side of EVAP canister, above spare tire.
Oct 15, 2010 at 12:27 PM
