2007 Chevy Colorado Check engine light stays on
SHORTYBRUNO
Computer problem
2007 Chevy Colorado Four Wheel Drive Automatic
my check engine light stays on. I thought it was the gas cap so i changes it. Light still on. i also took off the battery terminals and put them back on. Still light is on.
Mar 27, 2010 at 4:43 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the Catalytic converter...misfires...service it right away!
Mar 27, 2010 at 4:50 AM
SHORTYBRUNO
[quote:df6b78e115="shortybruno"]Computer problem
my check engine light stays on. I thought it was the gas cap so i changes it. Light still on. i also took off the battery terminals and put them back on. Still light is on.[/quote:df6b78e115] They told me that their is a vapor problem
Mar 27, 2010 at 4:56 AM
MERLIN2021
  • 17,250 POSTS
If you can post the actual codes they should be P XXXX, this is the only way I could tell you where to start...
Mar 27, 2010 at 6:46 AM
