2007 Chevy Colorado Air Condtioning Going on and off
61,200 MILES • 4 CYL • 2WD • MANUAL
BTUCKER1975
Hello! Heard you guys were the best :)
My question is........ My '07 Chevy Colorado 4cyl 2wheel drive pickup trucks air conditioning/heat system goes on and off. Sometimes it will work for an entire day (at the most) other times it will only last a few hours before it goes off and doesn't work until it comes on again. This happens on a daily basis. I am wondering if it might me a relay?? I have never heard of this. Usually when your air/heat stops, it usually doesn't ever come back on, unless you replace like the blower motor or relay etc.
My system comes on and off spiratically and for hours or a full day at a time in either an "off or on".
Please help! Thank you sincerely.
-Brian Tucker
Apr 18, 2010 at 3:18 PM
JJ127
my air works on the high fan speed only. theres a resistor under the dash by the fan motor. cost $25. i replaced this it worked fine, for a week anyway. from what the chevy mechanic told me is this seems to be a common problem
Apr 21, 2010 at 2:03 AM
