2006 Chevy Colorado Transmission won't go into park
MARCO_38
Transmission problem
2006 Chevy Colorado Four Wheel Drive Automatic 45000 miles
Transmission won't go into park. It hapenned spontaneously after trying to shift it in 3rd gear because I hadn't used those gears in a while (automatic transmission).
Just wondering what could cause this?
Mar 8, 2010 at 12:24 PM
HMAC300
  • 48,601 POSTS
depending won where your shifter is, column or floor. the floor has a cable and a clip could have come off or broken or the cable it self. If it's a column then the linkage could be bent.
Mar 29, 2010 at 11:22 AM
