2006 Chevy Colorado Multiple Misfire
59,000 MILES • 4 CYL • 2WD • AUTOMATIC
GAVIN1029
I had a misfiring problem and brought it to Autozone. They ran a diagnostics on it and said it was a number 1 misfire. I changed all the sparkplugs and the number 1 boot. It started running great and my gas mileage went up to where it should be. I drove it about 300 miles and it started running poorly again. I brought it back to Autozone and they ran another diagnostics on it and said it was a number 1 misfire again. I was told to switch the number 1 boot withthe number 3 boot to see if it changes from number 1 misfire to a number 3 misfire. If so it was a bad boot. I did that and brought it back to them for a third diagnostics check and now it is saying multiple random misfire. I was wondering what i can do to fix the problem myself. And maybe if it could be the box where all 4 wires run to. Please help. Thanks
Jun 16, 2010 at 4:28 AM
  • 75,988 POSTS
Random misfire is normally caused by vacuum leaks and bad fuel.
Jun 16, 2010 at 10:10 AM
GAVIN1029
So what what i need to check for a vaccum leak?
Jun 16, 2010 at 10:16 AM
  • 75,988 POSTS
You can use a vacuum gauge, or listen to a hissing sound around the intake manifold and vacuum hoses.
Jun 16, 2010 at 10:18 AM
GAVIN1029
so should i go ahead and change all four coils? or maybe just the number 1 and 3 coil and see what happens. i know they are like 60 something dollars a piece.
Jun 16, 2010 at 10:27 AM
  • 75,988 POSTS
Check the no.1 cylinder compression and injector disregard the coils at this time till you rule out this two
Jun 16, 2010 at 10:32 AM
GAVIN1029
how would i go about checking num 1 cylinder compression and injector. i really don't know too much about engines. just the simple things...
Jun 16, 2010 at 10:43 AM
BYATES
you need to clean your throttle body, it is easy and cheap
Jun 22, 2010 at 7:36 AM
