2006 Chevy Colorado misfire code
30,000 MILES • 4 CYL • 2WD • AUTOMATIC
PACMAN251
I have a 06 Colorado 2.8 liter and my service engine light came on a few days ago and I put a code scanner on it and it came up P0300 which is a random misfire. I then cleared the code and today the light came back on again with the same code. Is it ok to drive or do I need to get it repaired quickly? And what might be the causing the code?
Dec 20, 2008 at 1:26 PM
BRIAN 1
  • 1,030 POSTS
what cylinder was the missfire,or cylinders?was it missfiring at Idle?need more info,because there are several bulletins for this problem.if it is a single cylinder missfire I want you to swap it with a good coil on the vehicle and see if it changes to that cylinder. if it does not we have to go in a different direction.04-06 colorado's had ALOT of cylinder head problems with the intake valves sticking causing a light missfire at idle. I've replaced ALOT of cylinder heads on these vehicles. post back with what you find.
Dec 20, 2008 at 1:51 PM
