Driver window and door locks
73,600 MILES • 6 CYL • 4WD • AUTOMATIC
MOOSE1262
I left my key on in my truck accidently, now that i have jumpstarted the battery, the driver window and the locks do not work, i know there is a way to reset this but i don't remeber how, could you help me with this?
Dec 21, 2009 at 8:26 AM
RACEFAN966
  • 5,029 POSTS
According to Mitchelle it takes a scan tool to go in and relearn the bcm. How ever the widow and lock on not on the same circuit but they do share fuse 21 for power. Also according to mitchelle there is no reset required for battery replacement. Check fuse 21 first and if that is good then you will need to have the bcm scanned to reprogram it.
Dec 22, 2009 at 2:28 AM
DENNYP
  • 1,824 POSTS
If the fuse is good, you most likley have a bad driver window switch. I have had many of them go bad after jump starting or battery replacement. There is something inside them that gets a voltage spike and it kills the module.
Feb 2, 2010 at 12:24 PM
SUTTONJOHN
Mine did the same thing and i had to have the switch replaced...couple hundred bucks but everything works again
Sep 15, 2018 at 12:47 AM
JDSACCONE
  • 5 POSTS
Electrical problem
2006 Chevy Colorado Four Wheel Drive Automatic 21900 miles
I was tightening the positive battery terminal clamp and my wrench accidentally touched a piece of metal and sparked.
Since then my automatic door locks won't work either from the door switch or from the remote button.
Also, the driver side window won't work, either up or down, but all the other windows do operate from the driver side switches.
I checked all fuses and they are good and ring out.
Any suggestions?
The engine size is the 5 cyl
Thanks
David
Sep 15, 2018 at 12:49 AM (Merged)
FACTORYJACK
  • 4,159 POSTS
Does any of the other functions work from the remote, indicating it is at least functional, or are there any other than door locks. It looks like your left front door switch is also the door module. It controls door locks and the left front window only. Try removing the door lock fuse(#21) in the underhood fuse block for a few minutes. This supplies power to the logic portion of the door module. The fuse is good, correct? Also check if it has power to/across it. Since the door locks don't work with either the switch or keyless, I don't suspect a fault with the body control module, which is also the keyless receiver. I am suspecting logic lock on the drivers door module. When you reinstall the fuse it may work. Logic lock does not necessarily indicate a failure of the component, just a tie up, perhaps from a voltage spike due to the shorting of the battery.
JDSACCONE
  • 5 POSTS
There are no other functions on the remote but door open and lock. I removed the fuse for several minutes and still the power door lock will not function. I do however here a clicking sound near the fuse box when i try to unlock or lock and the horn and lights work when in the lock mode.
Any further suggestions?
David
JDSACCONE
  • 5 POSTS
Hello
I tried what you suggested to resolve my problem. Still unable to use door locks or front window.
Thanks
David
DENNYP
  • 1,824 POSTS
Do you have a DVOM? If so, do you know how to measure DC voltage with it?
FACTORYJACK
  • 4,159 POSTS
If you checked the fuses, you can check power and ground at the window switch. Try disconnecting and shorting both battery cables. This does about the same as before, but on a broader spectrum. After that and still with no success, you will probably need a scan tool to verify inputs are being received by the drivers door module(switch). If the inputs are being received, yet no outputs are being executed, you could have a faulty drivers door module.
BCAMOREVINO
I have heard that it is common. Dead battery, have to jump start, now drivers window and power door locks don't work.
JDSACCONE
  • 5 POSTS
Thank You for your help
David
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
I haven't heard that one myself, but id start with fuses. those can blow when a vehicle is jumped
FACTORYJACK
  • 4,159 POSTS
Is the problems corrected?
JDSACCONE
  • 5 POSTS
Been real busy at work. No time to trouble shoot the problem further as you suggested. I will investigate this weekend.
Thanks
David
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
JAMES ZUMWALT
Have the following issues with my 2006 Colorado, fan only works on high- looked at the plug and is burnt; fan making loud whinning sound; temp control **** only works in red or hot area. What do I need to look for in correcting the issues.
DAVE CAMPBELL
I have 2005 Chevy colorado I cleaned battery posts now drivers window will not work & door locks wont work either 3.5 engine auto trans. drivers window not working
the bcm lost its memory. you most likely will have to have it reflashed to bring them back on line
DAYTONSCOTT
the resistor is blown in the heater control were that burnt harness plugs into. GM should charge roughly 70 for parts (resistor and harness) and about 180 for labour.
RIVERMIKERAT
  • 6,106 POSTS
James was the answer from daytonscott helpful for you?
BIGHMAN35
truck when died i charge it and the driver side window and power locks wont work now
CADIEMAN
  • 3,544 POSTS
remove both switches and check for power.
2CP-ARCHIVES
  • 4,540 POSTS
hello i took my truck to get a paint job and when it came back the drivers window will not work and the power door locks will not work have you run across this problem before. pls help me to fix this problem. tks
SATURNTECH9
  • 30,869 POSTS
What did they paint?Did they take anything apart?
Sep 15, 2018 at 12:50 AM (Merged)
STEW
Power lock & power window control (drivers window) doesn't work
JDL
  • 16,098 POSTS
You can check some of the wiring going into the driver door on the hinge side of door. The wire harness may have a rubber boot protective covering, pull the covering back. Orange wire is voltage for door lock. Yellow wire is voltage for power window. Check for voltage on those wires, use voltage tester. Black wire is ground. You can also check fuses.
