2005 Chevy Colorado roter
11,300 MILES • 6 CYL • 2WD • AUTOMATIC
YOBYNNHOJ
I'm trying to remove the roter, The roter is behind the lug bolt plate.The lug bolt plate is in the way. I took off the caliper,the mounting that holds the pads, the 6 bolts holding the roter and lug bolt plate together and also the 4 bolts on the back by the speed sensor. The lug bolt plate will not come off. I tapped lightly on it but it won't come off. WHAT am I doing wrong, WHAT is holding it from coming off. All the manuals say to remove the hub/speed sensors, but it is not budging. PLEASE HELP!!!
Sep 11, 2010 at 8:42 AM
HMAC300
  • 48,601 POSTS
heres the way the pros do it. seems the onentitled way better way guys works easiest....
https://images.2carpros.com/forum/automotive_pictures/406719_colorado_brake_rotor_1.jpg
Nov 11, 2010 at 3:33 AM
