2005 Chevy Colorado P0506 code - Idle air control lower tha
2005 CHEVROLET COLORADO
COLORADO101
Engine Performance problem
2005 Chevy Colorado Four Wheel Drive Automatic 60.000 miles
My check engine light came on with a P0506 code - Idle air control system rpm lower than expected. Several of the option that I found on the web suggest that it could be the PCV valve or the Idle air control Valve (IAC). Can anyone tell me were these are located on a 2005 5 cyl colorado. I did find a site that tells how to test the IAC valve/motor, but I want to make sure I have the correct devices. Thanks
Oct 9, 2008 at 11:44 AM
BRIAN 1
  • 1,030 POSTS
SES Light Due to DTCs P0105, P0106, and/or P0506 - Clean Throttle Body
Models: 2004-2007 Buick Rainier
2002-2007 Chevrolet TrailBlazer
2004-2007 Chevrolet Colorado
2002-2007 GMC Envoy
2004-2007 GMC Canyon
2002-2004 Oldsmobile Bravada
2006-2007 HUMMER H3
2005-2007 Saab 9-7X
with any of the following engines:
2.8L (VIN 8 - RPO LK5)
2.9L (VIN 9 - RPO LLV)
3.5L (VIN 6 - RPO L52)
3.7L (VIN E - RPO LLR)
4.2L (VIN S - RPO LL8)
On rare occasions, a SES light may be experienced due to DTCs P0105, P0106, and/or P0506. There may or may not be an idle complaint accompanying the SES light. This may be due to excessive carbon build up in the throttle body.
clean the throttle body bore and plate for evaluation
Oct 10, 2008 at 2:38 AM
YOBDAB
I had this code pop up at 55K on my 2005 Mustang GT.
What I did to clear this code was clean my TB.
I turned the key to the "on" position (engine not running) and placed weights on my accelerator peddle. This opened the butterfly on my TB. From there I just used carb cleaner and a clean rag to clean the TB. Doesn't have to be a whole lot of gunk to make this code appear.
Mar 10, 2009 at 7:27 PM
