2005 Chevy Colorado Fuel Tank
65,000 MILES • 6 CYL • 4WD • AUTOMATIC
CJE527
I am presently having difficulty refueling the tank. When refueling, it seems as if there is a blockage in the area where the fueling neck meets the tank. I either pump the gas real slow or allow the fueling neck to fill and then wait for it to drain. Whats wrong and can a shade tree mechanic fix it.
May 14, 2008 at 10:48 AM
DENNYP
  • 1,824 POSTS
Is your check engine light on? You could have a restricted evap vent valve.
Jun 11, 2008 at 3:57 PM
DENNYP
  • 1,824 POSTS
Also, don't fuel the vehicle with the key on or engine running.
Jun 11, 2008 at 3:58 PM
