2005 Chevy Colorado abs kicks on when turning and braking
60,000 MILES • 4 CYL • 4WD • AUTOMATIC
KASTANZO
any ideas why my abs tries to kick on? have replaced right front wheel speed sensor....but still having this issue...diagnostic only picked up low idle air control valve...any correlation between the two?
Nov 8, 2008 at 7:49 AM
MICHAELWBC
I had the same issue with my 05 Colorado. With my truck, it was not the sensor it was the actual wheel bearing. The ABS senor reads off of the wheel bearing any "play" causes the sensor to indicate wheel slipage. May be or not be your problem as well.
Nov 12, 2008 at 4:56 AM
