2004 Chevy Colorado removing hub from front brake
MARICCI
Brakes problem
2004 Chevy Colorado Two Wheel Drive Automatic 124000 miles
I cant get the hub and rotor of my front wheel i removed caliber and all the bolts on back but still cant get it off. do i have to take off the abs sensor? is there something i am missing? Is the rotor pressed on? Help
Nov 8, 2009 at 10:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
unfortunately you have to remove the entire steering knuckle before you can remove the wheel hub assembly, and then to separate the rotor from hub assembly.
Apr 24, 2010 at 2:57 PM
