The spark plugs are fine. Is the throttle position sensor located at the throttle body or the foot pedal. There isnt a cable. Is the idle ar control valvle located on the throttle body or the intake manifold? It has a low, rough idle, water in the oil, misfire and iac codes.
Jan 27, 2010 at 7:51 AM
