2004 Chevy Colorado draining battery
2004 CHEVROLET COLORADO
KINGFISH4814
Electrical problem
2004 Chevy Colorado 6 cyl Two Wheel Drive Automatic
I have a colorado pickup that I changed the rt. front hub due to damage to the abs exciter ring. It was very low miles from a junk yard it had the abs sensor installed. After it was hooked back up the battery goes dead when it sets over night. Could it be a short in the sensor? Would installing a new sensor take care of the problem? It didn't drain the battery til it was all put back together..
May 5, 2009 at 10:59 PM
BMRFIXIT
  • 19,053 POSTS
Do not believe so
but you can disconnect that sensor and let it sit over night if next morning all OK you found the problem if not you need to do a battery drain test
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 5, 2009 at 11:10 PM
