2009 Chevy Cobalt Service ECS , ABS , Traction Control
2009 CHEVROLET COBALT
1,500 MILES • 4 CYL • FWD • MANUAL
MONGORAT427
MEMBER
1 POST
Service Ecs Light on . Goes in limp mode. What could cause this
Apr 12, 2010 at 8:43 AM
BMRFIXIT
✓Experienced Mechanic
Very new to have problems and should be under manufacture warranty
Need to be hooked on a scanner and checked for codes
As for things you can check for
Check and make sure battery terminals tight
Check fuses, check belts
Check wiring harness by each tire (ABS sensor)
let me know
Apr 12, 2010 at 9:18 AM
