2009 Chevy Cobalt Loud Squeak
1,100 MILES • 4 CYL • FWD • MANUAL
DESHAZO87
2009 Cobalt SS turbo. I hear a loud squeak, kind of like a bed makes when someone gets on it or makes a repeated movement. But, it only happens when it's cold out. I'm thinking maybe because it has a high performance suspension, the bushings are harder and are louder. I need help addressing the issue, I brought it to the dealer, and they could not verify the noise.
Mar 11, 2009 at 6:11 AM
RANDYMSW1
It is not because of your "high perfromance" suspension.
I have a 2009 Colbalt, 4 door sedan. I have the bottom of the line, basic model. I have also notice the loud squeak when it is cold outside.
I have 4,000 miles on my car, and just went in for my first oil change. I asked if they had any complaints about this issue and of course, they said no.
I drive over 2 speed bumps every morning to get out of my condo complex. If it is 40 degrees or lower, my suspension squeaks very loudly when driving over the speed bumps. After the car has been driven for several miles, the squeak goes away.
The only way the dealership can verify this is if you leave the car there over night, and they start to drive it on a cold morning.
In my opinion, it sound like the Lower control arm bushings that are squeaking.
May 7, 2009 at 5:43 AM
KARENCAREN
  • 72 POSTS
Is your car still under warranty? I think so, then you need to go to your dealer and let them check that problem.
May 12, 2009 at 2:44 PM
