if the fuses are okay the BCM needs to be replaced here is the location and the instruction on how to replace it below.
Body Control Module Programming and Setup
A new body control module (BCM) must be programmed with the proper regular production option (RPO) configurations. The BCM stores the information regarding the vehicle options and if the BCM is not properly configured with the correct RPO codes the BCM will not control all of the features properly. The Tech 2 software will automatically prompt you with the various RPO's available for the vehicle. Ensure that the following conditions exist in order to prepare for BCM programming:
1. This entire procedure has been reviewed before starting
2. The battery is fully charged.
3. A CANdi module is installed between the vehicle and the scan tool.
4. The ignition switch is in the ON position.
5. The data link connector (DLC) is accessible.
6. All disconnected modules and devices are reconnected before programming.
BCM Programming
Important: Use extreme care when verifying both the VIN and Odometer reading that is set in the service BCM. Once the VIN and Odometer are set in the replacement BCM it is impossible to change them, and if there is a mismatch, the part will be rendered useless.
To setup a new replacement BCM select Vehicle Control Systems, then navigate to Computer/Integrating Systems, once in the Computer/Integrating Systems menu select Module Replacement/Setup and follow the instructions on the scan tool.
If the BCM fails to accept the program, perform the following steps:
* Inspect all BCM connections.
* Verify that the scan tool has the latest software version.
SDM Part Number Learn Procedure
If the SDM is replaced the SDM part number must be learned by the BCM. Using a scan tool navigate to Vehicle Control Systems, Module Setup, Supplemental Inflatable Restraints then select Setup SDM Part Number In BCM. Follow the on screen directions.
Important: After programming, perform the following to avoid future misdiagnosis:
1. Turn the ignition OFF for 10 seconds.
2. Connect the scan tool to the data link connector.
3. Turn the ignition ON with the engine OFF.
4. Use the scan tool in order to retrieve history DTCs from all modules.
5. Clear all history DTCs.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Images (Click to enlarge)
Oct 23, 2010 at 5:46 PM
