Once you pull the oil fill cap off you can pull off the big plastic cover that sits over the engine. It isn't bolted down, so all you have to do is lift up on it and it will come right off. Once the plastic cover is removed, you will be able to see the canister where the filter goes. It's silver, it hangs directly off the side of the engine, closest to the front of the car, and the top of it has a black, plastic plug that you can remove by turning it with a socket or a wrench, but let me tell you it takes a big one - 1.25". If you don't have a socket that fits, then you can be creative and try to get it loosened another way. Be careful, don't ruin or bust the plastic top. Once you get it unscrewed, just lift up on the black plug and the filter will come right out with it. Put the new filter in. Make sure the filter canister is empty, and then put it back into the canister and tighten it up.
May 12, 2010 at 9:09 AM
