2008 Chevy Cobalt Automatic Locks
CJASON33
2008 Chevy Cobalt
The automatic door locks keep locking and unlocking by themselves. What would be making it do that and how do I fix it?
Feb 26, 2010 at 6:09 AM
BRIAN 1
  • 1,030 POSTS
It has been reported that an issue exists that will cause the door locks to cycle when driving and/or become inoperative from the door lock switches. When the condition is present the door locks are inoperative from the switches, however they work normally with the key fobs. (If equipped with Remote keyless Entry)It is recommended that you connect the Tech-2 to the vehicle and look at the door lock switch status,it should be reading "Idle". If it reads lock or unlock then check for a possible sticking door lock switch and replace as necessary.
also check the drivers window switch for corrosion,very common.
Feb 26, 2010 at 12:17 PM
