2007 Chevy Cobalt Virbation
38,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHUTNEY
My car is virbating when driving! which is making a small virbating noise in the front of my car! And do I need to get all my fluid flushed b/c that is what the tech said
Oct 30, 2008 at 6:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Fluids wouldn't have anything to do with vibrations from the vehicle. Although it is good habit to change your fluids at the recommended intervals which are in your owner's manual. Most common causes of front end vibration would be worn suspension parts. Seeing as how this is a relatively new vehicle, I don't believe that this would be the problem. Perhaps you should check your tires to ensure they are inflated properly, have good tread and check for any signs of unusual wear on the treads such as wearing only in one certain spot instead of all the way across the tread surface. Post your resluts and I will follow up.
Oct 31, 2008 at 9:08 PM
