2007 Chevy Cobalt check engine light
HELPMENOW
2007 Chevy Cobalt 4 cyl Front Wheel Drive Automatic
check engine light came on had codes erased and a week later it started runnin rough and the ck engine lite came bk on took it to a dealer and they pulled up the code that the 4th cylinder was misfiring they cleared it and seems to be runnin ok but they said it will come bk on they suggest i get the fuel injectors cleaned or replace the 4th spark plug or wire
Oct 23, 2009 at 2:40 PM
  • 31,937 POSTS
HI there,
i would be replacing all the plugs and leads, check the engine for vacuum leaks around No 4 cyl, also consider having the injectors serviced as well.
mark (mhpautos)
Oct 23, 2009 at 4:30 PM
