2007 Chevy Cobalt CEL but No codes
CORYSTI
  • 2007 CHEVROLET COBALT
  • 4 CYL
  • FWD
  • MANUAL
  • 55,000 MILES
Since my car ran into some water I've had a Check engine light on but when I rent a code reader from the local auto parts store It tells me no codes- pass! My car wont' start and she will get fire on the 2-3 cylinder but nothing from the 1st and 4th. Coilpacks and spark plugs are good. I've also checked the fuses and I was wondering how can I check a sensor without having to replace it?
Monday, January 18th, 2010 AT 6:14 PM
ERNEST CLARK
  • 1,730 POSTS
Sometimes your check engine light will flash, but your computer won't retain the code if it doesn't reoccur often enough. But if your light stays lit, then the computer should definitely have a code waiting for you.
When you had it scanned, what kind of scanner did you/they use? All scanners aren't created equal.
If you haven't already done so, have your computer scanned by a GM code reader that will have the capability to monitor all of the systems in real time as you drive.
If you can't interpret the information, have a mechanic do it.
This will pinpoint your problem without you having to chase down ghosts. That would only waste your time and money.
Thursday, January 28th, 2010 AT 6:05 AM
