2006 Chevy Cobalt Squeaking Upon Acceleration
2006 CHEVROLET COBALT
SHOUSEHOLDER
Noises problem
2006 Chevy Cobalt Automatic 66,000 miles
Within the last week my Cobalt has been squeaking on acceleration. It doesn't matter if it's hot or cooler, whether I accelerate faster or slower.
Aug 10, 2009 at 8:03 PM
MMPRINCE4000
  • 8,548 POSTS
Start by inspecting the serpintine belt, look for cracks worn spots. If OK, try this:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot
Sep 10, 2009 at 8:48 AM
SHOUSEHOLDER
[quote:13141e87e6="mmprince4000"]Start by inspecting the serpintine belt, look for cracks worn spots. If OK, try this:
Check CV boots for any signs of leakage or cuts/rips in rubber boot[/quote:13141e87e6]
I actually took it in to my local dealership/service center and was it was my brakes- because it's been so humid lately the magnesium in the brakes rub and make that squeaking sound. Apparently, a lot of people in my area are having the same issue because of the humidity.
Thanks though!
Sep 10, 2009 at 10:10 AM
MMPRINCE4000
  • 8,548 POSTS
Glad you found the problem.
Sep 11, 2009 at 6:15 AM
