O2 sensor
60,000 MILES • 4 CYL • FWD • AUTOMATIC
COTYANN
Where is the O2 sensor located at on this car?
Jun 27, 2010 at 5:34 PM
SATURNTECH9
  • 30,868 POSTS
The upstream/o2 sensor 1 is screwed into the exhaust manifold.The down stream/o2 sensor 2 is screwed into the exhaust pipe right before the cat.
Here is a guide and diagrams below to show you how to change both sensor positions.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Cheers
Jun 27, 2010 at 5:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle has 2 oxygen sensors, one in rear of engine compartment, in exhaust manifold and the other in rear of engine compartment in the exhaust piping near catalytic converter
Jun 27, 2010 at 5:41 PM
SATURNTECH9
  • 30,868 POSTS
Pretty simple repair make sure you get a o2 sensor socket it will make the job easier and help protect the new sensor when you put it in.
Jun 27, 2010 at 6:19 PM
