2006 Chevy Cobalt Front Driver Tire- Rattling noise
36,000 MILES • 4 CYL • 2WD • AUTOMATIC
KRYSTAL URBAN
I am a girl and have no nothing about cars, so might question is probably really easy; but my front drive side tire makes a rattling noise when i go over bumps or any uneven surfaces on the road. Also when i stop and the car front end goes down a little- it squekes. I just replaced the oil pan- because it had a hole in it (not sure how), but happened after i had to get my car towed. But like 2-3 weeks after the oil pan,the noises start. If you know what it could be, and about how much? It would really help me out!
Sep 9, 2008 at 3:11 AM
BRIAN 1
  • 1,030 POSTS
when you had the vehicle towed they could of damaged something.check the r/f lower control arm bushing,the seperate and come apart real easy.that will make a squeak noise because the control arm will rest on the cradle. also check the link pin they get play in them and make a clunk noise,both of these are very common problems for this year cobalt.post back with what you find
Sep 9, 2008 at 1:24 PM
