2006 Chevy Cobalt display error code
2006COBALTSSQUESTION
Computer problem
2006 Chevy Cobalt Automatic 42000 miles
I used to drive a Plymouth Neon, and to display the trouble code, all you had to do was quickly within 5 seconds, switch the ignition 3 times and then back on to show any stored codes. My question is: is there a simular way with the Chevy Cobolt? I would just like to know in advance of returning my car to CarMax what codes/trouble the computer has stored. I would also like to add that while the "check engine light" came on, I cycled thru my various displays and my engine temp reading was ___ just 3 dashes, no temp reading. I pulled over after a couple of miles and my overflow fluids were not overheating. My temp readings have since returned, and are in normal ranges, but the check engine light is still lit. Thank you for any assistance, bob
Nov 6, 2008 at 12:32 AM
BMRFIXIT
  • 19,053 POSTS
Unfortunately you need an OBDII reader for this one
I would suggest checking gas cap
most local part store have the service available for free
check with your local parts store ….
they can scan it for you and give you the codes
if you like you can post the codes for more help
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 6, 2008 at 1:48 AM
