2006 Chevy Cobalt Car is making a kocking noise in drivers
2006 CHEVROLET COBALT
18,762 MILES • 4 CYL • FWD • AUTOMATIC
FIELDS5302
My car is making a knocking or tapping noise when I drive it, it seems to make the noise in the drivers front tire area behind the fire wall. The noise gets really worse when i turn the steering wheel just a little to either side, it is really bad when i do this around 55MPH.
We have changed the driver side axle and the hub bearing assembly but it did not help.
I have not noticed anything else that makes with worse other than only turning the steering wheel just until i feel pressure on the wheel. You can hear the noise slow down as the speed goes down until you drop below 30MPH.
The noise reminds me of a shaft being warped and and hitting another piece of metal or a jack hammer but i looked the front end over and cannot find anything.
If you have any idea's please help
Mar 11, 2009 at 10:56 AM
JAMES W.
  • 2,394 POSTS
Is the noise at wheel speed? Are you sure it's not the bearing on the other side? Please advise
Mar 11, 2009 at 6:06 PM
